Knowledge Base Article
Why does the F-Tile Serial Lite IV IP Deterministic Latency Design Example fail Simulation in the Quartus® Prime Pro Edition Software version 25.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1, you might fail the simulation for the F-tile Serial Lite IV IP Example Design if you performed the following during example design generation:
  • Choose "Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit (Production 1 4x F-Tile)" or "Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit (Production 2 4x F-Tile)" for the "Select Board" parameter in the Example Design Tab
Resolution
To work around the above problem, you can perform the following during example design generation:
  • Choose "No Development Kit" for the "Select Board" parameter in the Example Design Tab
This problem was fixed starting with version 25.1.1 of the Quartus Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
