Knowledge Base Article
Why does the F-Tile Ethernet Intel® FPGA Hard IP Design Example fail to generate on Windows*?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1, the F-Tile Ethernet Intel® FPGA Hard IP Design Example will fail to generate on Windows*.
When attempting to generate the design example on Windows*, an error similar to the one shown below will be seen:
Error: Failed to generate example design example_design to: ********\eth_f_0_example_design
Resolution
To work around this problem when using Intel® Quartus® Prime Pro Edition Software version 22.1, generate the design example using Linux*. Once generated the example design can then be compiled on Windows*.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
