Knowledge Base Article
Why does the F-Tile Dynamic Reconfiguration Design Example in 400GE-4 FHT Base Variant with Enabled AN/LT fail to function correctly in hardware?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4,  the F-Tile Dynamic Reconfiguration Design Example in 400GE-4 FHT Base Variant with Enabled AN/LT will fail to function correctly in hardware.
Specifically, after executing the tcl script to run the design example, the System Console will hang while displaying the following messages:
Successfully Read  Port 16 CSR Register offset = 0x142c0, data = 0x2006
Successfully Read ETHERNET ANLT Channel 16 Register anlt_seqcfg_csr4, offset = 0x2c0, data = 0x2006
Successfully Read  Port 16 CSR Register offset = 0x240, data = 0x0
    INFO: port_state value = 0x00000000
Resolution
To work around this problem in version 23.4 of the Quartus® Prime Pro Edition Software, perform the following steps:
  1. Change to the directory <design example project directory>/hardware_test_design/hwtest_f/eth_f_dr
  2. Open the file ftile_eth_anlt_cfgcsr_inc.tcl in a suitable text editor
  3. Locate the following snippet of code:
proc get_reset_port_state_status_0 {ch} {
puts "\tINFO: Channel $ch : Checking port state status..."
set timeout 10
set i 0
while {1} {
if {$ch > 0xf} {
set rdata0 [reg_read [expr 0x200 + [expr $ch * 0x4]]]
} else {
set rdata0 [reg_read [expr 0xc0 + [expr $ch * 0x4]]]
puts $::fileid "\t\tINFO: port_state value = $rdata0"
set port_state_value [expr ($rdata0 >> 29) & 0x1]
if {($port_state_value == 1 ) || $i >= $timeout } break
incr i
if {$port_state_value == 1} {
puts "\tINFO: port_state signal is high "
} else {
puts "\tERROR: mport state does not go high"
  1. Change the following line
TO:
set rdata0 [reg_read [expr 0x200 + [expr [expr 0x0f & $ch] * 0x4]]]
  1. Save the file
  2. Run the design example in hardware using the modified script files in System Console
This problem has been fixed starting in version 24.1 of the Quartus® Prime Pro Edition Software.
Updated 2 months ago
Version 3.0
