Knowledge Base Article
Why does the F-Tile CPRI FPGA IP simulation Design Example fail while generating the files in the “support_logic” folder in the QTLG flow only when we run the QTLG for the F-Tile CPRI FPGA IP simulation example design multiple times?
Description
Due to a problem in the F-Tile CPRI FPGA IP webcore version 23.2, you might see a failure while generating the files in the “support_logic” folder with the F-Tile CPRI FPGA IP simulation design example while running the Quartus® Tile Logic Generation(QTLG) flow in the F-Tile CPRI FPGA IP simulation example design multiple times.
Resolution
To work around this problem in the F-Tile CPRI FPGA IP simulation example design webcore version 23.2, follow the steps below.
1.    Modify the "cpri_ii_0_testbench/ip_components/tb_top.qsf" files by commenting out the line as shown below:
           #set_global_assignment -name SYSTEMVERILOG_FILE support_logic/tb_top_auto_tiles.sv
2.    Modify the "cpri_ii_0_testbench/testbench/tb_top.sv" file by introducing the following definition condition for “tb_top_auto_tiles tb_top_auto_tiles ()”:
           `ifndef ALTERA_RESERVED_QIS // Code excluded for Quartus Synthesis
            tb_top_auto_tiles tb_top_auto_tiles ();
       `endif
3.    Execute the specified commands, namely "quartus_ipgenerate" and "quartus_tlg," as indicated in Section 2.8 of the User Guide."
This workaround would not be necessary when the user doesn’t generate the F-Tile CPRI FPGA IP simulation example design simulation example design for CPRI FPGA IP with an Agilex™ F-Tile device.
This problem is scheduled to be fixed in a future release of the F-Tile CPRI PHY FPGA IP.
Updated 3 months ago
Version 2.0
