Knowledge Base Article
Why does the F-Tile Architecture and PMA and FEC Direct PHY IP not show any error when configuring with a PMA width of 16b and TX and RX double-width enabled?
Description
Due to an error in the F-tile Architecture and PMA and FEC Direct PHY IP, when configuring with a PMA width of 16b and TX and RX double-width enabled you might not see any error message for the wrongly selected configuration in the Quartus® Prime Software version 22.1.
The IP wizard doesn't complain and allows you to generate the IP files.
During the SLG stage of compilation the following errors will be seen.
Error(21843): Conflict 0
Error(21843): Rule: gdr_wrapper::topology_mapping_mux_rule @
Error(21843): as.sw_topology != UX16E400GPTP_XX_DISABLED_XX_DISABLED ||
gdr.z1577a.topology == UX16E400GPTP_XX_DISABLED_XX_DISABLED
Error(21843): Rule:
gdr_virtual_channel::topo_and_stream_down_to_maib_adapter_tx_and_rx_fifo_mode_and_width_rules
@ gdr Error(21843): gdr.z1577a.topology !=
gdr.z1577a.u_e400g_top.e400g_stream15_tx_en == FALSE ||
gdr.z1577a.u_e400g_top.e400g_stream15_sys_clk_src !=
E400G_STREAM15_SYS_CLK_SRC_XCVR ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_aib_if_fifo_mode !=
E400G_STREAM15_TX_AIB_IF_FIFO_MODE_REGISTER ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_excvr_if_fifo_mode !=
E400G_STREAM15_TX_EXCVR_IF_FIFO_MODE_PHASECOMP ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_primary_use !=
E400G_STREAM15_TX_PRIMARY_USE_DIRECT_BUNDLE ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_xcvr_width inside
{E400G_STREAM15_TX_XCVR_WIDTH_10,E400G_STREAM15_TX_XCVR_WIDTH_20,E400G_STREAM15_TX_XCVR_WIDTH_32}
Error(21843): Rule: gdra_gdr_e400g_top::e400g_stream15_sys_clk_src_rule
@ gdr.z1577a.u_e400g_top Error(21843):
(gdr.z1577a.u_e400g_top.e400g_25g_15_sys_clk_src ->
MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_rx[0].rx_ehip.x_bb_f_ehip_rx.sys_clk_src)
!= E400G_25G_15_SYS_CLK_SRC_XCVR ||
(gdr.z1577a.u_e400g_top.e400g_25g_15_tx_en ->
MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_en)
== FALSE || gdr.z1577a.u_e400g_top.e400g_stream15_sys_clk_src==
E400G_STREAM15_SYS_CLK_SRC_XCVR Error(21843): Rule:
gdra_gdr_e400g_top::e400g_stream15_tx_aib_if_fifo_mode_rule @
== FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_aib_if_fifo_mode ->
MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_aib_if_fifo_mode)
!= E400G_25G_15_TX_AIB_IF_FIFO_MODE_REGISTER ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_aib_if_fifo_mode ==
E400G_STREAM15_TX_AIB_IF_FIFO_MODE_REGISTER Error(21843): Rule:
gdra_gdr_e400g_top::e400g_stream15_tx_enable_rule @
(gdr.z1577a.u_e400g_top.e400g_25g_15_tx_primary_use ->
MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_primary_use)
== E400G_25G_15_TX_PRIMARY_USE_DISABLED ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_en == TRUE Error(21843): Rule:
gdra_gdr_e400g_top::e400g_stream15_tx_excvr_if_fifo_mode_rule @
== FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_excvr_if_fifo_mode
MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_excvr_if_fifo_mode)
!= E400G_25G_15_TX_EXCVR_IF_FIFO_MODE_PHASECOMP ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_excvr_if_fifo_mode ==
E400G_STREAM15_TX_EXCVR_IF_FIFO_MODE_PHASECOMP Error(21843): Rule:
gdra_gdr_e400g_top::e400g_stream15_tx_primary_use_rule @
== FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_primary_use ->
!= E400G_25G_15_TX_PRIMARY_USE_DIRECT_BUNDLE ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_primary_use ==
E400G_STREAM15_TX_PRIMARY_USE_DIRECT_BUNDLE Error(21843): Rule:
gdra_gdr_e400g_top::e400g_stream15_tx_xcvr_width_rule @
== FALSE || (gdr.z1577a.u_e400g_top.e400g_25g_15_tx_xcvr_width ->
MAC_LOOPBACK.PCSMAC.fgt_10g_single|directphy_f_0|dphy_hip_inst|persystem[0].perehip_tx[0].tx_ehip.x_bb_f_ehip_tx.tx_xcvr_width)
!= E400G_25G_15_TX_XCVR_WIDTH_16 ||
gdr.z1577a.u_e400g_top.e400g_stream15_tx_xcvr_width ==
E400G_STREAM15_TX_XCVR_WIDTH_16 Error(21843): Input variables:
Error(21843): as.sw_topology == UX16E400GPTP_XX_DISABLED_XX_DISABLED
Error(21843): user.bb_f_ehip_tx[0] ->
Error(21843): is_used == TRUE Error(21843): location == E400G_25G_15
Error(21843): sys_clk_src== SYS_CLK_SRC_XCVR Error(21843):
tx_aib_if_fifo_mode == TX_AIB_IF_FIFO_MODE_REGISTER Error(21843): tx_en
== TRUE Error(21843): tx_excvr_if_fifo_mode ==
TX_EXCVR_IF_FIFO_MODE_PHASECOMP Error(21843): tx_primary_use ==
TX_PRIMARY_USE_DIRECT_BUNDLE Error(21843): tx_xcvr_width ==
TX_XCVR_WIDTH_16
The problem is gdr.z1577a.u_e400g_top.e400g_stream15_tx_xcvr_width
inside
tx_xcvr_width == TX_XCVR_WIDTH_16 doesn't seem to  be allowed.
Resolution
To work around this problem, ensure that only supported modes are generated, as documented in the PMA Supported Modes section of the F-Tile Architecture and PMA and FEC Direct PHY IP User Guide.
Updated 2 months ago
Version 2.0
