Knowledge Base Article
Why does the EMIF toolkit fail to recognize the memory interface when it is generated in the Platform Designer?
Description
If you cannot find the memory interface generated by the Platform Designer when using the EMIF toolkit, verify that you have copied the .sopcinfo file into your project folder.
Resolution
Copy the .sopcinfo file into your project folder.
Updated 3 months ago
Version 2.0
