Knowledge Base Article
Why does the Dual Simplex Example Design in GTS JESD204C FPGA IP, with the data path clocking mode set to System PLL and JESD204C DS wrapper set to “Dual Simplex applied on JESD204C PHY,” fail to generate when the data rate exceeds 10,312.5 Mbps?
Description
The Dual Simplex Example Design generation fails when the data rate exceeds 10,312.5 Mbps due to a System PLL clock constraint being violated.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software versions 25.1 and 25.1.1, download and install patch from the appropriate link below.
- Download version 25.1 Patch 0.29 for Windows and Linux (.zip)
- Download version 25.1.1 Patch 1.17 for Windows and Linux (.zip)
- This problem is fixed beginning with the Quartus® Prime Pro Edition software versio 25.3.
Updated 1 month ago
