Knowledge Base Article
Why does the DMA test of the Intel® FPGA P-Tile Avalon® Memory Mapped (Avalon-MM) IP for PCI express* generated example design causes the host system to hang?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.4, you may encounter above issue when performing the DMA test of the Intel® FPGA P-Tile Avalon® Memory Mapped (Avalon-MM) IP for PCI express* generated example design.
Resolution
This problem has been fixed in the Intel® Quartus® Prime Pro Edition software versions 20.1
Updated 3 months ago
Version 2.0
