Knowledge Base Article
Why does the Design Space Explorer report "unknown" timing results?
Description
Due to a problem in the Quartus® II software versions 11.0 SP1 and earlier, the Design Space Explorer (DSE) may not report timing information correctly if the TimeQuest timing analyzer is not explicitly identified as the timing analysis tool. Instead, DSE reports the timing slack for all seeds as "unknown".
Resolution
To work around this problem, add the following assignment to the Quartus II settings file (.qsf) for your project:
set_global_assignment -name USE_TIMEQUEST_TIMING_ANALYZER ON
This problem has been fixed begining with the Quartus II software version 11.1.
Updated 2 months ago
