Knowledge Base Article
Why does the Deinterlacer II IP core drop a line for every other frame in simulation?
Description
Due to a problem with Intel® Quartus® Prime software version 16.1, you may encounter the above problem in simulation if the Deinterlacer II IP core is configured with "Bob" deinterlacing algorithm and produce one frame for every F0 field.
Resolution
To work around this problem configure the Deinterlacer II IP to produce one frame for every F1 field.
This problem has been fixed in Intel Quartus Prime software version 17.1.
Updated 1 month ago
