Knowledge Base Article
Why does the 'Cannot Set Parameter vsr_mode' error occur when upgrading the F-Tile PMA/FEC Direct PHY Intel® FPGA IP example design in the Intel® Quartus® Prime Pro Edition Software version 23.2 and onwards?
Description
In the Intel® Quartus® Prime Pro Edition Software version 23.2 and onwards, changes to VSR modes assignments have been introduced:
  • VSR_MODE_LOW_LOSS (replacing ENABLE in the Intel Quartus Prime Pro Edition Software version 23.1)
  • VSR_MODE_HIGH_LOSS (new configuration)
  • VSR_MODE_DISABLE (replacing DISABLE in the Intel Quartus Prime Pro Edition Software version 23.1)
Resolution
To work around this problem, the QSF assignment in the QSF file within the project needs to be updated to the appropriate required settings.
Updated 2 months ago
Version 3.0
