Knowledge Base Article
Why does the bar size in lspci log not match the configured size in the IP parameter when using Intel® Stratix® 10 H-Tile/L-Tile Avalon® Memory Mapped (AvalonMM) Hard IP for PCI Express*?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2 and earlier, you may see bar size in lspci log doesn't match with the configured size in the IP parameter when using Intel® Stratix® 10 H-Tile/L-Tile Avalon® Memory Mapped (AvalonMM) Hard IP for PCI Express*.
Resolution
This problem is fixed in Intel® Quartus® Prime Pro Edition Software version 22.2 and onwards.
Updated 1 month ago
