Knowledge Base Article
Why does the BAR offset of the MSI-X Table and PBA for Intel® Stratix® 10 PCI Express* Hard IP fail to take effect?
Description
Due to the issue of Intel® Quartus® Prime Pro software, the MSI-X Table BAR offset and PBA specified in the GUI for Intel® Stratix® 10 PCI Express* Hard IP, fail to take effect. This can be seen by using the “lspci” command on Linux OS.
Hence the MSI-X functionality will fail to operate correctly due to the address of MSI-X Table overlapping the PBA.
This issue impacts the following IP cores:
Intel® Stratix® 10 Avalon®-MM interface for PCI Express*
Intel® Stratix® 10 Avalon®-ST interface for PCI Express*
Avalon®-MM Intel® Stratix® 10 Hard IP for PCI Express*.
Resolution
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 19.3.
Updated 3 months ago
