Knowledge Base Article
Why does the avl_ready signal stay low when using the hard memory controller with multi-port front end port widths of 128 bits?
Description
Due to an issue in the hard memory controller in the Quartus® II software version 12.1sp1, theavl_ready signal will stay low if using 128-bit width ports. Calibration may pass successfully, but the controller will not assert the avl_ready signal.Resolution
To work around this issue, it is recommended to use port widths of 64 or less.
This issue has been fixed in Quartus II software version 13.0sp1.
Updated 2 months ago
