Knowledge Base Article
Why does the assembler fail to run after the update_mif flow?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition software version 19.4, you may see this failure when running the assembler for Intel® Arria® 10 designs after running the update_mif flow using the following command:
quartus_cdb <project name> --update_mif.
Resolution
To work around this problem, use the followng alternative flow to update your mif files.
  1. Enable the "Enable intermediate snapshot" in Assignment -> Settings -> Complier Settings
  2. Update the Memory Initialization file
  3. Run the quartus_fit --finalize instead of quartus_cdb --update_mif
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 20.1
Updated 2 months ago
Version 2.0
