Knowledge Base Article
Why does the Arria 10 HDMI Example Design intermittently fail read transfers after data rate switching above 5Gbps?
Description
Due to a problem with the Intel® Arria® 10 HDMI design example, TX PMA recalibration fails to run after data rate switching. This can cause hardware failure for data rates >5Gbps
Resolution
This problem has been fixed starting in Intel Quartus® Prime version 17.0.2
Updated 2 months ago
Version 2.0
