Knowledge Base Article
Why does the Arria 10 Hard IP for PCI Express CraWaitRequest_o never deassert for CRA internal configuration space registers?
Description
Due to a problem in the Arria® 10 Hard IP for PCI Express® in Avalon®-MM mode, the Control Register Access(CRA) waitrequest signal (CraWaitRequest_o) never deasserts for accesses to the CRA configuration space registers (offsets 0x3c00 - 0x3c6c).Resolution
Modify the following always block starting at ~ line 340 in the file altpciexpav128_cr_avalon.v to add the item in bold to the sensitivity list:
// Select the returned read data and read valid
always @(addr_decode_reg or AdTrReadData_i or AdTrReadDataVld_i or
A2PMbReadData_i or A2PMbReadDataVld_i or
P2AMbReadData_i or P2AMbReadDataVld_i or
RuptReadData_i or RuptReadDataVld_i or
RpReadData_i or RpReadDataVld_i or
RdBakReadData_i or RdBakReadDataVld_i or CfgReadDataVld_i)
This problem is scheduled to be fixed in a future release of the Quartus® II software.
Updated 3 months ago
