Knowledge Base Article
Why does the ALTECC decoder simulation have glitches when the parity bit is incorrect?
Description
In the Quartus® II software version 12.1 SP1 and later, on the output of the ALTECC decoder megafunction you may see glitches on the parity bit for all single-bit errors.
Resolution
To work around this problem, add one pipeline stage on the decoding result by setting output latency of 1 clock cycle in ALTECC wizard.
Updated 3 months ago
Version 2.0
