Knowledge Base Article
Why does the 10G Multi-IP configured design, including the F-tile Ethernet Intel® FPGA IP, fail at “Support Logic Generation” when implementing multiple instances?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1, you might see a “Support Logic Generation” failure with your design, including the F-tile Ethernet Intel® FPGA IP configured, fail at “Support Logic Generation” when implementing multiple instances.
Resolution
There is no workaround available.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
