Knowledge Base Article
Why does swinfo2header create invalid EXCEPTION_ADDR entries?
Description
There is a known issue in the 11.x versions of the swinfo2header command line tool. The issue causes the value of "EXCEPTION_ADDR" within the header file to be set incorrectly to 0 rather than the correct value.
As a workaround, the user can make a manual change to the EXCEPTION_ADDR value after generation, or alternatively use the swinfo2header tool supplied with version 10.1sp1. This issue shall be fixed in a future version of the Quartus® II tool.
Updated 1 month ago
