Knowledge Base Article
Why does simulation of the Intel® Stratix® 10 FPGA JESD204B IP design example fail when using the ModelSim SE version 10.5c?
Description
Simulation of the Intel® Stratix® 10 JESD204B design example generated in the Intel® Quartus® Prime Software version 17.1.1 or earlier might fail when simulating at a resolution of 1 ps usng the ModelSim SE version 10.5c.
Resolution
To work around this problem, remove the 1 ps resolution from the vsim command line by removing '-t ps' from the vsim command in the modelsim do file msim_setup.tcl.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 18.1.
Updated 3 months ago
Version 2.0
