Knowledge Base Article
Why does simulation fail for the Hard IP for PCI Express when CVP is enabled?
Description
The simulation model for the Hard IP for PCI Express does not work correctly when CvP is enabled within the Quartus® II software.  If you attempt to run the simulation testbench with CvP enabled, the testbench will fail.
Resolution
There is no plan to fix this problem.
Updated 1 month ago
Version 2.0
