Knowledge Base Article
Why does SignalTap II Logic Analyzer display 'Program the device to continue' message even though the design was compiled with the latest SignalTap II file(.stp)?
Description
Due to a problem in the Quartus® II software version 14.0 and later, you may see the message 'Program the device to continue' and the following error message when you run SignalTap™ II Logic Analyzer on a design which was compiled with old SignalTap II libraries located in the ./megafunctions folder.
Error (261009): Cannot run SignalTap II Logic Analyzer. SignalTap II File is not compatible with the file programmed in your device. The expected compatibility checksum value is [SOF Checksum]; the value read from your device is 0xA1B2C3D4
Resolution
To work around this problem, remove the ./megafunctions folder from your Quartus II project so that the Quartus II software uses correct version of the SignalTap II libraries.
This problem is scheduled to be fixed in a future release of the Quartus II software.
Updated 2 months ago
Version 2.0
