Knowledge Base Article
Why does Signal Tap show "Program the device to continue" when using the JTAG-Over-Protocol IP to tap logic within a PR (Partial Reconfiguration) partition?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4 and earlier, the Signal Tap Logic Analyzer IP will show "Program the device to continue" when attempting to tap logic within a PR partition when also using the JTAG-Over-Protocol IP.
Resolution
To work around this problem, disable the Enable use of TCK-ENA option within the JTAG-Over-Protocol IP.
This problem is scheduled to be fixed in a future release of Quartus® Prime Pro Edition Software.
Updated 28 days ago
