Knowledge Base Article
Why does Signal Tap Logic Analyzer fail to report the resource estimation?
Description
In the Intel® Quartus® Prime Pro Edition Software version 18.1 and earlier, you may see the ALM usage and Memory usage for the Signal Tap instance are unavailable.
Resolution
This report is scheduled to be removed from the Intel® Quartus® Prime Pro Edition Software. You can check the Signal Tap instance resource usage in the synthesis report.
Updated 3 months ago
Version 2.0
