Knowledge Base Article
Why does Scaler II MegaCore generate incorrect output when it receives elongated control packet?
Description
In the Video and Image Processing Suite MegaCore functions version 10.0 and earlier, the Scaler II MegaCore® function with the Enable run-time control of input/output frame size option turned on may generate incorrect output when it receives an elongated control packet.
Affected Configurations
This issue affects your system if you instantiate the Scaler II MegaCore function directly after you instantiate the Color Plane Sequencer or Chroma Resampler MegaCore function.
Design Impact
The affected configuration may generate incorrect output or crash.
Solution Status
This issue is fixed in the Video and Image Processing Suite  MegaCore functions version 11.0.
Resolution
Avoid using the Scaler II MegaCore function with the Enable run-time control of input/output frame size option turned on directly after the Color Plane Sequencer or Chroma Resampler MegaCore function.
Updated 2 months ago
Version 3.0
