Knowledge Base Article
Why does reconfiguration of Intel® Stratix® 10 devices fail in Active Serial (AS) mode if you reset the serial flash device before toggling nCONFIG?
Description
Reconfiguration of Intel® Stratix® 10 devices in Active Serial (AS) mode may fail if a system asserts the external reset of the serial flash device used for configuration before reconfiguration is triggered.
This is because the Secure Device Manager (SDM) sets initialization values in the serial flash device during the first configuration of the Intel Stratix 10 device but doesn’t set them again during reconfiguration.
Hence, if the serial flash device is reset before reconfiguration, the initialization values are eliminated, causing reconfiguration to fail.
Resolution
To work around this problem, do not reset the serial flash device before a reconfiguration.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 20.1.
To resolve this problem, update the latest device manager firmware for the Intel® Quartus® Prime Pro Edition Software 21.1/21.2/21.3/21.4/22.1/22.2/22.3.
The latest device manager firmware versions are available from the following link:
What is the latest device firmware for Intel® Agilex™ and Intel® Stratix® 10 devices?
Updated 3 months ago
Version 2.0
