Knowledge Base Article
Why does quarter rate DDR3 UniPHY-based controller design show low read efficiency?
Description
The low read efficiency is caused by one of the settings in the DDR3 controller for quarter rate design. When the read latency is longer (e.g: larger CAS latency number), the controller will stall internal read commands from executing because the maximum number of pending read commands is reached.
Resolution
The current workaround for this problem is to change the parameter MAX_PENDING_RD_CMD from 16 to 32 in the <instance_name>_c0.v file as follows:
From
MAX_PENDING_RD_CMD = 16
to
MAX_PENDING_RD_CMD = 32
This problem is fixed starting with the Quartus® II software version 13.1.
Updated 2 months ago
