Knowledge Base Article
Why does programming the csr_sysref_singledet register bit to '1' when the JESD204B Intel® FPGA IP is in ILAS phase bring the IP back to CGS state?
Description
Due to a known problem in the Intel® Quartus® Prime Standard and Pro Edition Software, programming the csr_sysref_singledet register bit to '1' when the JESD204B Intel FPGA IP is in ILAS phase will bring the IP back to CGS state. This impacts Intel Agilex®, Intel Stratix® 10, Intel Arria® 10 and Intel Cyclone® 10 GX device families.To work around this problem, avoid programming the csr_sysref_singledet register bit when the JESD204B Intel FPGA IP is in ILAS phase.
Resolution
To work around this problem, avoid programming the csr_sysref_singledet register bit when the JESD204B Intel FPGA IP is in ILAS phase. There is no fix planned for this.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
