Knowledge Base Article
Why does Platform Designer report the IP Synchronization Results window when no IP file has been changed?
Description
Due to a problem in Platform Designer Pro, you may see the IP Synchronization Results window pop up after opening a Platform Designer system, even when the "Platform Designer system IP file path" is the same as the "New IP file."
Resolution
It is safe to ignore this pop-up window if there is no change in the IP file.
Updated 3 months ago
Version 2.0
