Knowledge Base Article
Why does Platform Designer not terminate the SystemVerilog interface input ports when using the TERMINATION port property?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v21.4 and earlier, the HDL code generated by Platform Designer is incorrect when a SystemVerilog HDL interface input port is terminated.
For example, when the following settings are applied:
      add_interface_port avalon_slave address address input 10
      set_port_property address TERMINATION true
      set_port_property address TERMINATION_VALUE 0xFFFFF
Platform Designer will generate the incorrect HDL code:
        my_ip my_ip_0 (
                .bus     (my_ip_0_bus),
                .address (10'b1111111111)
        assign readdata = my_ip_0_bus.readdata;
        assign my_ip_0_bus.address = address;
        assign my_ip_0_bus.write = write;
        assign my_ip_0_bus.writedata = writedata;
Resolution
To work around this problem, manually edit the generated HDL file (found under the <my_ip>/synth/<my_ip>.v):
        my_ip my_ip_0 (
                .bus     (my_ip_0_bus),
        assign address = 10'b1111111111;
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 22.1.
Updated 1 month ago
Version 2.0
