Knowledge Base Article
Why does PCIe core transmit corrupted TLP when using Descriptor Data interface with MSI?
Description
When using the PCIe Incremental Compile Module (ICM) for the Descriptor/Data interface and a MSI transaction is sent while a TLP is being transmitted. This TLP will be corrupted on the PCIe bus.
Resolution
To work around this problem, ensure that signaling of MSI transacitons occurs after a TLP is completed. In other words, the MSI transaction must be sent between the previous EOP and the next SOP.
Updated 3 months ago
Version 2.0
