Knowledge Base Article
Why does PCI Express link training fail intermittently ?
Description
Due to a bug, you may see link training failure with the Hard IP for PCI Express® IP Core due to the transmission of corrupted TS1s.
The Hard IP core LTSSM state cycles between the Detect and Polling.Config state. Due to the corrupted TS1s the link partner can only proceed to the Polling.Active state, causing link training to fail.
Resolution
Modify the IP to use the soft reset controller, please refer to the related solution below:
This issue is fixed in v13.1.2 and later of the the Quartus® II software.
Related Articles
Updated 1 month ago
