Knowledge Base Article
Why does nios2-elf-gdb cannot start Text User Interface (TUI) terminal or display backspace action correctly?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.1 to 22.2 and Intel® Quartus® Prime Standard Edition Software version 21.1, this problem may occur when opening the nios2-elf-gdb TUI terminal or backspacing.
Failure signatures are:
- When opening the TUI terminal, the nios2-elf-gdb will report "Cannot enable the TUI: error opening terminal [TERM=xterm]"
- When backspacing, the action is incorrectly displayed as spacing
This is due to a bug in the terminfo folder settings.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 21.1 to 22.2 and Intel® Quartus® Prime Standard Edition Software version 21.1, do the following:
- Use the command, export TERMINFO_DIRS=/etc/terminfo:/lib/terminfo:/usr/share/terminfo
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.3 and Intel® Quartus® Prime Standard Edition Software version 22.1.
Updated 2 months ago
