Knowledge Base Article
Why does Nios® V processor design example script returns error "riscv-none-embed-objcopy: command not found"?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2 and RiscFree* IDE for Intel® FPGAs, this error might be seen when running the Nios® V processor design example script.
This is because the script is not using the RISC-V GNU Compiler Toolchain provided in the RiscFree* IDE for Intel® FPGAs.
Resolution
To work around this error in the Intel® Quartus® Prime Pro Edition Software version 22.2 and RiscFree* IDE for Intel® FPGAs, do the following:
  • Change the command "riscv-none-embed-objcopy" to "riscv32-unknown-elf-objcopy"
This problem is currently being fixed in the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 3 months ago
Version 2.0
