Knowledge Base Article
Why does Nios® II processor software fail to build using Windows Subsystem for Linux (WSL) with Ubuntu 18.04.5?
Description
This problem may be seen in any Quartus® Prime Software version when building the Nios® II processor using WSL with Ubuntu 18.04.5.
This is due to different return value when running the command “wslpath -u .” in Nios® II Command Shell.
  • Working: The command returns “.”
  • Failing: The command returns “wslpath: .”
The returned string of “wslpath: .” breaks the Nios® II software build flow.
Resolution
Run “wslpath -u .” in Nios® II Command Shell. If the return string is “wslpath: .”, implement any of the following workarounds:
  • Use Ubuntu version older than 18.04.5.
  • Provide the full BSP directory path to the BSP_DIR in both create-this-bsp and create-this-app scripts.
Updated 3 months ago
Version 2.0
