Knowledge Base Article
Why does my PCI Express endpoint not respond to the Link Disable request from the root complex?
Description
You may experience problems commanding the Altera® PCI Express® core to the Link Disable state, when configured as an endpoint.  The PCI Express core may transmit a truncated (incorrect length) TS1 message during the transition to Electrical Idle.
In simulation, your Root Port BFM may complain about a "TS Ordered set length error".
Resolution
The workaround at this time is to avoid using this optional feature.
Updated 24 days ago
Version 2.0
