Knowledge Base Article
Why does my multi-instance design example for the F-tile Ethernet Intel® FPGA Hard IP fail to achieve link on an intermittent basis?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.3, the reset logic for the multi-instance design example for the F-tile Ethernet Intel® FPGA Hard IP is improperly implemented. This leads to intermittent link failures upon initial bring-up of the design example. This problem exists for all multi-instance design examples, regardless of IP variant.
Resolution
To work around this problem, perform the following steps:
  1. Navigate to the <design example name>/hardware_test_design/ directory.
  2. Open the eth_f_hw.v file. This is the top level of the design example.
  3. Change the following line:
assign rst_n[i] = arst;
TO:
assign rst_n[i] =  source_rst_n;
  1. Compile the design example.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 22.4.
Updated 3 months ago
Version 2.0
