Knowledge Base Article
Why does my Intel® Stratix® 10 FPGA L-tile simplex receiver have low jitter tolerance when no transmitter is used for that channel?
Description
Due to a problem in the Intel® Quartus® Prime Software version 16.1.2 ES Edition and earlier calibration code, your Intel Intel® Stratix® 10 device simplex receiver may have low jitter tolerance when no transmitter is used in that channel.
Resolution
To work around this problem, you can instantiate a simplex TX transceiver and merge it into the same channel as the simplex RX transceiver.
After calibration is complete, you can write a 1'b0 to address offset 0x10F to stop the TX serializer clock from toggling and save power. If user-mode recalibration must be run again, you must first turn the TX serializer back on by writing a 1'b1 to address offset 0x10F.
Updated 3 months ago
Version 2.0
