Knowledge Base Article
Why does my Intel® HDMI* IP Design Example for Intel Cyclone® 10 GX devices generate Intel Arria® 10 transceiver QSF constraints when using the Intel® Quartus® Prime software version 21.1 and earlier?
Description
Due to a bug in the Intel® Quartus® Prime Pro Edition Software versions 21.1 and earlier, your Intel HDMI IP Design Example for Intel Cyclone 10 GX devices will generate Intel Arria 10 transceiver QSF constraints.
Resolution
To fix this problem you can replace the “XCVR_A10" prefix with “XCVR_C10" in the Intel HDMI IP Design Example QSF file.
For example, replace the following:
set_instance_assignment -name XCVR_A10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_A10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_1ST_POST_TAP 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_1ST_POST_TAP 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_1ST_POST_TAP 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_A10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[3]
with the following:
set_instance_assignment -name XCVR_C10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_SLEW_RATE_CTRL SLEW_R5 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_C10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_VOD_OUTPUT_SWING_CTRL 31 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_PRE_TAP_1T FIR_PRE_1T_POS -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_1T 0 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SIGN_1ST_POST_TAP FIR_POST_1T_POS -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_1ST_POST_TAP 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_1ST_POST_TAP 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_1ST_POST_TAP 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_PRE_TAP_2T 0 -to fmc_dp_c2m_p[3]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[0]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[1]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[2]
set_instance_assignment -name XCVR_C10_TX_PRE_EMP_SWITCHING_CTRL_2ND_POST_TAP 0 -to fmc_dp_c2m_p[3]
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 3 months ago
Version 2.0
