Knowledge Base Article
Why does my HPS design fail Analysis & Synthesis but report zero errors?
Description
Due to a problem in the Quartus II software version 12.1, you may see Analysis & Synthesis fail by report zero errors if you have not connected your Hard Processor System (HPS) directly to FPGA pins. HPS I/O must be connected to pins without any intervening logic.Resolution
To work around this problem, make sure the HPS I/O are connected directly to FPGA pins.
Future releases of the Quartus II software will give an error message for this incorrect connection.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
