Knowledge Base Article
Why does my Hard IP for PCI Express fail when I have a BAR address size smaller than 4 bits?
Description
Due to a problem with the Quartus® II software, you can generate invalid BAR sizes smaller than the required 16 bytes specified by the PCI Local Bus Specification. The Platform Designer will not display any warning messages. The design will not work due to the undersized BARs failing to be enumerated.
Resolution
To work around this problem, ensure that the connected componets in the Platform Designer result in a BAR size between 16 bytes and 2 GB (a minimum of 4 address bits).
This is not scheduled to be fixed in a future Quartus II software release.
Updated 1 month ago
