Knowledge Base Article
Why does my FFT simulation in NCSim* or Xcelium* fail to run?
Description
When simulating the Quartus® Prime Standard Platform Designer created FFT core using ncsim_setup.sh or run_xcelium.sh scripts, the command output will end with the following:
ncelab: *F,CUMSTS: Timescale directive missing on one or more modules.
ncsim: 15.20-s006: (c) Copyright 1995-2016 Cadence Design Systems, Inc.
ncsim: *F,NOSNAP: Snapshot 'test_program' does not exist in the libraries.
The reason for this output is due to elaboration settings in the ncsim_setup.sh or run_xcelium.sh scripts.
Resolution
To work around this problem, edit the ncsim_setup.sh or run_xcelium.sh files with the following changes:
  1. Find the line defining the variable "USER_DEFINED_ELAB_OPTIONS" and change it as shown below:
               USER_DEFINED_ELAB_OPTIONS="-timescale 1ps/1ps"
            This change sets a default timescale for verilog files without timescale.
     2.   Find the line defining the variable "USER_DEFINED_SIM_OPTIONS" and change it as shown below:
            USER_DEFINED_SIM_OPTIONS="-input \"@run\""
           This change instructs the simulator to run until $finish.
Updated 3 months ago
Version 2.0
