Knowledge Base Article
Why does my EMIF IP RDIMM design have invalid assignments for SDA/SCL signals after compilation?
Description
Due to a problem in the Quartus® Prime Pro Edition software versions 25.1.1, 25.3, and 25.3.1, the Fitter does not automatically place the I2C SDA/SCL signals when they are not explicitly assigned.
Resolution
To work around the problem, manually assign legal locations for the following signals on the AC1 lane:
- SDA: index 10
- SCL: index 11
For details, see the “Address and Command Pin Placement” table in the External Memory Interfaces Agilex® 7 M‑Series FPGA IP User Guide (DDR5): Address and Command Pin Placement.
Additional Information
Affected Quartus® Prime versions:
- 25.1.1
- 25.3
- 25.3.1
This problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 4 months ago
Version 7.0No CommentsBe the first to comment
