Knowledge Base Article
Why does my design fail to pass the Intel® Quartus® Prime Pro Edition Software “Support Logic Generation” phase when using a combination of the F-Tile Ethernet Intel® FPGA Hard IP with PTP variant and an F-Tile PMA Direct PHY variant?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.2, the combination of an F-Tile Ethernet Intel® FPGA Hard IP with PTP variant and an F-Tile PMA Direct PHY variant will fail to pass the Intel® Quartus® Prime Pro “Support Logic Generationphase with the following error message: “Error (21842): Solver failed to find a solution”.
Resolution
To work around this problem in Intel® Quartus® Prime Pro Edition Software version 21.2 perform the following steps:
  1. Navigate to the <pma_direct_variant>/synth directory.
  2. Open the “directphy_f_hip.sv” file.
  3. Change the following lines FROM:
a. localparam  local_bb_f_ehip_e400g_ptp0_aib2_div2_clk = bb_f_ehip_e400g_ptp0_aib2_div2_clk;
b. localparam  local_bb_f_ehip_e400g_ptp1_aib2_div2_clk = bb_f_ehip_e400g_ptp1_aib2_div2_clk;
TO:
a. localparam  local_bb_f_ehip_e400g_ptp0_aib2_div2_clk = "__BB_DONT_CARE__";
b. localparam  local_bb_f_ehip_e400g_ptp1_aib2_div2_clk = "__BB_DONT_CARE__";
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition software version 21.4.
Updated 3 months ago
Version 2.0
