Knowledge Base Article
Why does my Configuration via Protocol (CvP) design hang the PCIe bus after a CvP core fabric load?
Description
The PCIe® bus can hang when using the CvP Update with Revision Flow if any partitions that are used for CvP become empty. The choices in the Quartus® II software when creating a partition for CvP Update with Revision Flow are Empty, Source, Post-Fit, and Post-Synthesis. The default is Empty to comply with Partial Reconfiguration requirements.
Resolution
When using CvP Update with Revision Flow, ensure that no CvP partitions use the Empty option. Ensure all partitions specify Source, Post-Fit, or Post-Synthesis based on your system\'s need.
Updated 2 months ago
Version 2.0
