Knowledge Base Article
Why does my Arria 10 XAUI PHY NCSIM script load with a fatal error?
Description
Due to a problem in the Quartus® Prime software versions 17.0 and earlier, you might see the Quartus-generated NCSIM simulation scripts for the Arria® 10 XAUI PHY load with the the following fatal errors:
ncelab: *F,CUMSTS: Timescale directive missing on one or more modules.
ncelab: *F,NOSNAP: Snapshot 'xaui.xaui' does not exist in the libraries
Resolution
To work around this problem, perform the following steps:
1) Go to generated simulation model project directory below:
    <project_dir>/<instance_name>/altera_xcvr_xaui_1*/sim
2) Open "a10_xcvr_xaui.sv" in text editor.
3) Add time scale directive (eg: `timescale 1 ps / 1 ps) before model declaration.
    a. Look for line with "module a10_xcvr_xaui #("
    b. Insert "`timescale 1 ps / 1 ps" in line before "module a10_xcvr_xaui #(".
4) Save "a10_xcvr_xaui.sv"
5) Navigate to <project_dir>/<instance_name>/sim/cadence
6) Run "nscim_setup.sh" using NCSIM simulator tool.
This problem is scheduled to fixed in a future release of the Quartus Prime software.
Updated 1 month ago
Version 2.0
