Knowledge Base Article
Why does my Altera Hard IP for PCI Express hang on Txs read in root port modes?
Description
Due to a problem in the Quartus® II 15.0 software, in root port mode, reads via the Txs interface might hang (not complete) following several read access through the CRA interface.
Resolution
This behavior is caused by the Avalon-MM bridge not increasing the credits consumed counters for TLPs generated from the CRA interface.
The workaround is:
  1. Install Quartus 14.1.
  2. Go to the Quartus 14.1 installation directory and find the following:
    1. <version>/ip/altera/altera_pcie/altera_pcie_av_hip_avmm/avalon_mm_128
    2. <version>/ip/altera/altera_pcie/altera_pcie_av_hip_avmm/avalon_stif
  3. Copy all files to the same folders of your Quartus 15.0 installation, overwriting all the existing files. Then reopen Quartus/Qsys 15.0 and re-generate the Hard IP.
  4. Please note the above directories are used for both Arria 10 and Arria V devices.
This is scheduled to be fixed in a future release of the Quartus software.
Updated 1 month ago
Version 2.0
