Knowledge Base Article
Why does my 1G/10G or 10GBASE-KR PHY design fail Link Training in Verilog HDL simulation?
Description
Due to a problem in Quartus® II software version 14.0 Intel® Arria® 10 Edition, you may see the following (or similar) warnings in simulation when Link Training is enabled.
"Warning: (vsim-3533) [FOFIW] - Failed to open file
'USER_QUARTUS_INSTALLATION_PATH/acds/quartus/../ip/altera/alt_xcvr/altera_xcvr_10gbase_kr/arria10/
cpu/kra10_cpu_imem.ver' for writing."
Following these warnings, Link Training will fail.
Resolution
To workaround this problem, perform the following steps:
1. Navigate to the directory in which the IP was generated:
<USER_IP_GENERATION_DIR>/altera_avalon_onchip_memory2_140/sim/
2. Within this directory, locate 2 Verilog HDL files with names similar to that shown below:
krip_altera_avalon_onchip_memory2_140_<RANDOM_CHARACTERS>.v
3. Locate the following parameter line similar to the following in each of the files from above:
parameter INIT_FILE = "/USER_QUARTUS_INSTALLATION_PATH/acds/quartus/../ip/altera/alt_xcvr/
altera_xcvr_10gbase_kr/arria10/cpu/kra10_cpu_imem.hex";
4.) Change each parameter to:
parameter INIT_FILE="kra10_cpu_Xmem.hex";
