Knowledge Base Article
Why does my 100GE-4, 100GE-2, 200GE-4, or 400GE-8 FGT reconfigurable variant of the F-tile Ethernet Multirate Intel® FPGA IP with PTP enabled always read out 0’s for the TX and RX TAM counter and valid registers?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1, 100GE-4, 100GE-2, 200GE-4, or 400GE-8 FGT reconfigurable variants of the F-tile Ethernet Multirate Intel® FPGA IP with PTP enabled will always read out 0’s for following registers:
- ptp_tx_uim_tam_info1[30:16]
- ptp_tx_uim_tam_info1[31]
- ptp_rx_uim_tam_info1[30:16]
- ptp_rx_uim_tam_info1[31]
Resolution
There is no workaround for this problem. You are advised to skip the UI Adjustment step in the PTP software flow.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 1 month ago
Version 3.0No CommentsBe the first to comment
